No Preloaded navigation aids on Garmin GPS72H
rs1
17 Oct 2011
Hi all,
I carry a Garmin GPS 72 (no longer made) as a backup to my chartplotter. I had problems with keys falling off the keypad, and Garmin have replaced it with a GPS 72h. The 72 was preloaded with nav aids (lights and so forth), but the 72h has nothing. Garmin say they've stopped loading this information as it was out of date, and they would now have to pay for this data. They suggested I might get similar information from a third party supplier, but after a couple of hours trawling the web the will to live is dwindling. Has anyone else come across this? I know out of date information is unreliable, but I always use paper charts/almanacs etc to confirm anything important, and it's nice to have something loaded as a guide.
Fantasie 19
23 Mar 2009
Chichester, West Sussex
Hi all,
Where do you sail??
Amulet
25 Jun 2007
Oban
www.flickr.com
Spend £50 on these charts for your computer - the whole UK. You can then draw the points and routes you care about on the screen and download them to the 72.
(This, in my opinion, is not very good software if you want to use it to navigate, but £50 for all UK charts ain't bad.)
rs1
17 Oct 2011
Ermmm... which chart software?
Sandy
31 Aug 2011
On the Celtic Fringe
duckduckgo.com
I use a Garmin 60CSx for all sorts of things and have been very, very dissapointed in Garmin's mapping offerings, i.e. way out of date and no update path, thankfully there is an Open Source Project that allows you to both edit and download maps.
There is an Open Source Charting Project, but it looks in its infancy. I would follow Amulet's advice and buy the charts and down load what you need onto the GPS.
Fantasie 19
23 Mar 2009
Hi all,
So what you are looking for is a list of buoys/lights that you can load into the GPS?
Do you have a data cable for the GPS - without that it won't talk to anything so I'm assuming yes....
What kind of plotter do you have??? Can it export data to an external source ie. a PC???
Thinking the easiest thing will be to transfer your waypoints from the plotter to a PC, and then load that file into the GPS72....
In the Solent where I am there are a number of sites that will give you huge lists of buoys as a downloadable GPX file (for the racers) - but I can't see anything for your area...
rs1
17 Oct 2011
In reality, I can spend a few winter evenings with charts and almanacs loading the waypoints and lights which are relevant to my (current) cruising areas - I do have a data cable and I've found a bit of free software which will let me do this more easily on a laptop and download to the 72h. I think I'm just a bit miffed that Garmin have withdrawn the preloaded data facility. Going on the maxim that suspect data is worse than no data at all, perhaps they've done me a favour......
My chartplotter (also Garmin) sadly doesn't have a port suitable to transfer out my waypoints.
Fantasie 19
23 Mar 2009
Same thing from visitmyharbour.com but for £30 - suitable for using with SeaClear...
Load that on the PC, plug your GPS in and transfer... seemples.... :D
B.t.w, I bought my GPS72 about two years ago I think - and it wasn't preloaded either... I have loaded up a set of free waypoints from one of the Solent racing web sites, but as per ProDave I use it purely as a GPS, navigating from waypoint to waypoint and cross referencing to a (paper) chart when I need to...
rs1
17 Oct 2011
I think the preloaded information in the GPS72 was limited in its usefulness, but can still be downloaded from Garmin:
http://www8.garmin.com/support/download_details.jsp?id=228
Can this be transferred the the 72H?
Andy
Thanks, Andy. Not sure about this - the Garmin site has several warnings that loading the Point of Interest database to the wrong unit may render it inoperable, and then it would need to be sent back to them for reprogramming.... I started this thread because I didn't like having lost something when the unit was repaced, but I am now questioning what I actually need and use the GPS it for. This leads me to the conclusion that it's better to load only the specific waypoints and lights/buoys which are relevant to me and my cruising areas - I can then update them when I make changes to my charts, and feel confident they are accurate and reasonably in date.
I am grateful for the excellent advice everyone has come up with.
