Alastairdent
Finally got our engine going, after about 10 attempts in the last 2 weeks. The engine on the sailing barge hasn't been run since we sailed her over from the nederlands.
I couldn't figure out what was stopping it from starting. Air filter ok, starter batteries charged, spinning over, fuel bled through new filters . . .
Eventually, I remembered the sign behind the oil heater. This says (rough translation) "Turn off the stove before starting the engine.". So I did, and the engine started . . .
This is odd, because although they are both fed from the same header/day tank, they don't share pipework. The tank is about 3ft above the engine. The only thing I can think of is that the lift pump on the engine isn't working, and it relies on the 'head' of diesel. When the stove is on, the slight fuel flow to the stove is enough to create a slight vacuum in the day tank - the air breather is small - and slow/prevent enough fuel from getting to the engine.
Any of you engine experts out there agree? If the engine lift pump is working, I wouldn't have thought that the slight flow of fuel to the drip-burner diesel stove could possibly stop the fuel from getting through to the engine.
