The orange warning lights that come on at the first part of the key turn are not coming on, if I continue to turn the engine starts .should I be looking for a fuse? Thank you in advance,
Check if you have 12v on the blue/red wire from the ignition switch when in the run position, if not its the switch. If there is 12v then follow the wiring to the warning light module.
