No engine instruments on the Flybridge, a basic solution.
That was my original plan, then i though of having the display on the flybridge to see any temp increases as early as possible. Might go back to plan A when i eventually find time to fit it. Are you happy with yours ?
Yes, happy with ours. Easy to install and seems to work okay. Had a problem with the display when it was outside warranty and when I rang the chap who does them he didn’t hesitate in replacing it FOC.
Love my silicone marine exhaust alarm.
No boat should set sail without one.
It almost saved my bacon one time.
Turned out to be a false alarm due to the idiosyncrasies of the injection elbow spray pattern. (Partially blocking spray)
However!! During investigation, we discovered our 1yr old (Lloyd's approved) exhaust hose was failing (just out of normal inspection sight line.)
So really, inadvertently it saved a bad day a year or so down the line.
