PaulRainbow
I've never understood the need to connect AC earth to the sea. The AC circuit already has a dedicated earth wire like any other AC circuit and is also protected by an RCD. The boat is only connected to mains AC when alongside and as such it's connected to AC earth. If I put a battery charger on my car I don't feel the need to drive an earth pole into the adjacent flower bed and connect the AC earth to it. Same applies when on a campsite with a mains power supply. I see no difference just because the boat is floating in water. Perhaps someone who knows could explain.
Your car charger is grounded through the power supply, as is your caravan or tent hookup. Your boat is when it's connected to the shore power, assuming the shore power is working correctly.
You find find anyone swimming in your flower bed, your caravan awning or your tent. You might see a swimmer in the water near your boat. Very tiny currents can disable a swimmer and cause drowning.
Don't forget, there are lots of boats with inverters and/or generators too, when at sea they need to be suitably earthed too.
For the real reason the AC grounding is connected to the water, Google "Electric shock drowning".
