Robin
You are probably correct as the AIS black box is fitted behind thes ame panel at the nav table that the VHF is mounted in. I will ask the installer man if he remembers and how easy it would be to route a link cable up to the coachroof mounted plotter and have a switch in the line so it was only feeding data if required. Many thanks.I also have a Standard Horizon DSC VHF and feed GPS data to it (NMEA0183) from my AIS (Digital Yacht AIT2000). I'm prepared to bet a dollar that your GPS feed also comes from the AIS (assuming it is mounted below deck near the VHF)!
If this is the case then the only remaining question is "will the plotter accept the NMEA0183 RMC sentence" . If it does, you just need the NMEA0183 wiring installing and you're done.
