JerryHawkins
I have installed a Simrad IS15 instrument system and when it is transmitting NMEA data, the interference (which can be heard on a world-band radio tuned to 500KHz) blots out my navtex radio reception. With the instruments off completely (or the NMEA output temporarily turned off) everything is fine.
Any ideas on how I can get rid of this interference. I've tried using screened twisted pair cable for all NMEA connections with the screen connected to ground (battery negative), but this hasn't helped. I've also tried using 0.1uF capacitors to 'de-couple' the data lines - no help. I'm now thinking of buying (over £200!!) an NMEA data combiner (see http://www.actisense.com) which 'opto-isolates' NMEA in and out.
Cheers,
Jerry
Cheers,
Jerry
