skyflyer
Is there any reason these can not be the same?
If not, how do you keep the NMEA ground separate?
All my normal 12v electrics are referenced to a common "earth" with everything connected back to a big busbar that is connected to battery negative.
My instrument network is the older two wire NMEA0183 type so basically a TX line an RX line and a common ground line.
Obviously the instruments also have an electrical supply, so there is a +12v and 0v (earth) terminal on each.
I am trying to minimise the wiring runs (not for economy but to save space in tight conduits) and wondered if i can reference everything to the instrument supply/boat earth or must i run a separate earth wire for the instrument signal network?
If I do run a seperate ground wire around the circuit then I assume it needs to be connected to something somewhere else how is it defined as an earth?
I'm sure I am overthinking this, but have now tied myself in knots!
