TiggerToo
Trying to get a Garmin 450 to communicate with a Navman 7200.
Garmin manual says
"The output from the GPS to VHF is set on Chanel 2 is at 0183 NMEA and I have checked the signal at the VHF end and there is a signal. Now the only thing to do now is get the format hhddmm or hhddmm.mm set for the radio to read the information . I did not have this info at hand but have it now and have forwarded it to Andy . it may require changing the output format from the GPS but it is a matter of reconfiguring it . "
Navman 7200 says
No position information is displayed.
The GPS cable may faulty or the GPS setting may be incorrect.
a) Check that the GPS cable is physically connected.
b) Check the polarity of the GPS cable.
c) Check the baud rate setting of the GPS if applicable. The baud rate setting should be 4800
for NMEA or 38400 for NAVBUS. Parity should be set to NONE.
what should I do? Where should I set up the confirgurations?
Garmin manual says
Navman 7200 says
