news for raymarine c-series
inverse
15 Mar 2005
hello.
A new update to raymarine c-series.. this is the update log:
version 2.14 for the C70, C80, and C120 Multifunction Navigation Displays. This software replaces versions 1.21 and 1.24 and 2.12. Version 2.14 adds several new enhancements summarized as follows:
Enhancements:
Range data is now shown to 3 decimal places
Support added for 3m / 6m depth contours
New Navionics rock symbols implemented
New Navionics polygon shoreline constructions supported
Added Colored Seabed Areas feature
Improved spot sounding presentation
Tide and current times are now shown as Local Time not UTC
Restart GPS now performs a cold start rather than master reset
EGNOS switch configuration setting added
Changed default MOB setting to position-based, rather than dead-reckoned
Supports trip data on SeaTalk up to 1000nm
version 2.12 for the C70, C80, and C120 Multifunction Navigation
Displays. This software replaces versions 1.21 and 1.24, which were the initial release versions.
Version 2.12 adds several new enhancements, and corrects some minor issues, summarized as follows:
Enhancements:
- Chart screen redraw is now much faster.
- Improved performance with Navionics XL3 cartography.
- A chart offset calibration function has been added to the Chart Setup.
- Improved display of various chartplotter icons and objects.
- A radar scanner range indicator is now available when in radar overlay mode.
- Dual-frequency options in single window have been improved.
- A new Digital Data Page application is now available. Windows of SeaTalk and NMEA navigation data can be
added to display pages.
- Enhanced "Page Setup" mode, with 5 programmable pages per set. Factory default page sets can now also
be edited, giving the user up to 25 custom pages.
Simply download from raymarine.com and follow the installation guide, you only need put the file in a CF card and insert in the unit, the upgrade process is auto.
Thanks for info.........
/forums/images/graemlins/confused.gifThis may seem like a stupid question - ? !! what size compact flash card will be needed to download this - 16, 32 MB ?
A reymarine c-series display, whit cmap charts? raymarine c-series display only use navionics gold charts.
Regards
Adrian, you need a CF card of the size of the update, I think that whit a 32 Mb card works fine...
Regards.
I followed all the instructions, didn't work, when I turned on the system it didn't go to an upgrade utility screen, I will try again and report back! Does anyone have any ideas?
