Spi D
Isn't fuel consumption a matter of the work performed and the efficiency in the engine and driveline?
Inspired by millions of years of refinement, the most efficient shape in water must be a fish.
Inspired by that, the easiest hull to move though water should be a sailboat, especially the racing designs. They are able to move relatively fast at the lowest power (multihulls are in a class of their own). Look at the water behind a sailboat moving forward: It barely curls the surface!
So an optimized sailing huill with a modern design engine and a proper driveline should be best of all. If you remove the sail you can remove the keel and minmize the drag.
From there any alterations on the move to mobo design shall bring compromises.
On the larger vessel side, nobody are more cautious about fuel than those who generate a profit, ie. the commercial ships. And they are long, implement bulbs on the bow to increase waterline and trim the trailing waves, and have rounded sterns to minimize drag. And they know to keep speed low.. Money talks.
Planing hulls have the benefit of lifting the hull out of the water. Since the density of water is some 800 times that of air, this provides for less resistance to overcome once the power to build the hydrostatic lift has been generated. And this is why consumption/distance improves at speeds where the planing hull is 'in air' and at low speed, when it pushes slowly forward at speed not building a large drag behind it.
I think.
I think.
