mil1194
If a diesel starts easily according to the expected procedure (not all have glowplugs) and the oil pressure picks up to spec within a few seconds there is nothing fundamentally wrong with it. If it revs up, out of gear, happily to the rated max rpm without sounding like a bag of spanners being shaken, and without immense gouts of smoke or steam, thats even better. Hard to check much more without a proper test run to look at operating temperature and so forth which need a more sustained run. Oil can be black but not thin or sludgy, no obvious oil or fuel leaks and coolant system should be filled to spec and stay there.
A basic diesel is a far simpler and forgiving beast than petrol, give it clean fuel and enough air and it runs, pretty much end of, its not fazed by some damp in the area. But, a very modern diesel with electronic common rail injection and emission control systems is just as complex as a modern petrol engine, simply in a different way.
+1
