new style watermaker
newtothis
28 May 2012
If it's as good as they say, it's pretty neat, but I think I can manage without for pottering around the Solent
Likewise, I try never to be more than a day's sail from fresh gin, so of little use to me.
But I've read/seen that the filters can be a pain with trad watermakers, and this seems to do without.
Fr J Hackett
26 Dec 2001
Saou
The video stopped working for me, so how many liters per hour does it produce?
It required me to turn off my add blocker so I haven't read it but that's the first question I would ask as those that need a watermaker on a boat as opposed to a liferaft need a lot and it doesn't seem to have that capability.
Yngmar
6 Dec 2012
Gone cruising
Supposedly costs only $50 (but that's probably without pre-filters, etc.). And it's small. Produces only 0.3 liters per hour, which is survival stuff, not showering or laundry. Uses 20 Wh per liter, so 6 W per hour runtime (making 0.3 liters in that time).
Theoretically you could just get 100 of these for a total $5000 and make 30 liters an hour drawing 600W (per hour).
But for the same price you can get a modern energy recovery watermaker which makes the same 30 liters an hour while drawing only 110W and it's a lot more compact than 100 suitcases.
geem
27 Apr 2006
Caribbean
Who told you that? I have been running my home built watermaker for 8 years making 200 l/hr. Not sure why you think filters are a pain
newtothis
28 May 2012
Who told you that? I have even running my home built watermaker for 8 years making 200 l/hr. Not sure why you think filters are a pain
No one in particular. Just something I seem to have picked up from various utubes and stories.
Mhvoiceuk
9 Oct 2003
Brighton
Yngmar
6 Dec 2012
Gone cruising
I’ve been looking at these . Schenker do a suitcase version for about £5000.00 ( Aquatrek) , but also found a Chinese manufacturer on Alibaba who will sell single units for under £800.00 which promise “up to 150l/hr” ( suspicious ) Wholesale Solar powered DC12V DC24V Suitcase type Small water maker salty water desalination system Drinking watermaker From m.alibaba.com
Anybody want to be a guinea pig ?
That's a low pressure system which cannot handle seawater. You can buy those for household water cleaning: 5 Stage Reverse Osmosis Unit | Toolstation
The table on the Alibaba listing clearly states, intake TDS must be under 1000 ppm. Seawater is 35'000 ppm or so. Design pressure 100 psi (6.8 bar) - seawater RO requires around ten times that pressure.
There is a related product on the bottom that does have the right numbers for seawater, but costs significantly more: Compact Suitcase Portable Seawater Desalination Machine 240l/d - Buy Salt Water Treatment System,Portable Water Purification Systems For Africa,Compact Seawater Maker Product on Alibaba.com
