wizard
I would never even concider polycotton, the cotton content will give you problems with rotting, colour fastness, shrinkage and mildew.
PVC goes stiff with U.V degradation.
Sunbrella is an Arylic canvas and it's worth noting that their stated max wash temp is 30 and not 40 degrees. The fibres will contract with heat at 40 degrees and shrink. Bear this in mind if washing.
Another problem with older canvas is when it's never cleaned, dirt becomes ingrained over the years and stiffens the fabric making it less flexiable. I'd also recommend taking the canvas off the frames every year and cleaning the frames, the canvas can "stick" to the frames when dirty and then the canvas is tight when trying to stretch down at the sides.
Acrylic canvas including Sunbrella should be fitted tight and will then stretch in a few days to a user friendly fit.
If it's taken off for a while it recoils, contracts and will be tight again the first time it's put back on
Most will know we are not the cheapest, but anyone with our work will have adjustable end plugs on the frames in most cases (occasionally there is a valid reason why they are not used). These are expensive fittings and the end lug can be wound in or out, hence lengthening or shortening the framework and hence you can adjust the tension in the canvas if a slacker fit is required.
The end lugs can also be wound completely out and changed for different lengths which can be brought, they come in 3 sizes each with around 20mm of adjustment.
Hope this all helps.
John
www.tecsew.com
Have you had any luck in sourcing the stainless steel zips yet?
