prv
I would not have called taking a starter motor off 'a major job'.
Fair point
Do come and have a go on my DS sometime. It requires the removal of the RH front suspension sphere, steering column, air filter, exhaust downpipe, exhaust manifolds and heat shield. Easier if you take the front wings (and headlamp steering mechanism) off too, along with the hydraulic pump. This is why I like working on my cramped, inaccessible boat engine ... it's just so easy in comparison!
My engine doesn't have an oil filter - VP MD1!
The family owned a 2CV for a while. It takes real skill to design a vehicle that is so maintenance-unfriendly!
Are you sure? My MD2 has so I would be surprised if yours didn't have one.
I had a 2CV and I disagree - it's the most maintenance-friendly car I have ever owned. There is only one nasty, which is the need to remove the fan to set the points ... that's why the wholly electronic 1-2-3 ignition system is so popular. Otherwise I found it a fantastically easy car to work on - probably because it was designed to be maintained and repaired by village blacksmiths with little by way of specialist tools or knowledge. The DS, by contrast, was so beyond the skills of rural garages that Citroën had flying repair squads to mend them.
As an example of easy maintenance, it took me 20 minutes to change all four shock absorbers in mine ... and ten of those minutes were spent working out the first one.
Did you ever change the front wheel bearings? I had to make a tool from hardened and tempered En24, with a lever about 8 ft long to unscrew the bearing retainer.
I did this on my Austin Allegro (I know!). I got a tractor socket 3/4" drive and a 3/4" to 1/2" reducer, connected my ratchet drive - wouldn't budge so I put a 4' scaffold tube on it and jumped on it. The ratchet broke immediately (pawls I think). Eventually removed it with proper 3/4" bar and scaffold tube.Did you ever change the front wheel bearings? I had to make a tool from hardened and tempered En24, with a lever about 8 ft long to unscrew the bearing retainer. The rear brake pipes corroded and changing them was a major task as some went through the chassis. Naturally they were not standard Bundy pipes but needed to be made up specially by the local dealer.
Assuming that it's the same driveshaft nut as a proper Mini, it's the same one as a 2CV as well. I'd be surprised if the Allegro needed 250 lb-ft, though.
I need to get a complete set of metric combination spanners (8mm to 19mm) to keep on the boat. I've seen them at under a fiver from CPC but have been advised that I need to spend £30-40 for reasonable quality. Any ideas?
