pcatterall
Just about to order a new mainsail (and hope to get the usual good advice from you guys!)
The original set up was with the old fashioned rotating boom (with which I was never really happy.
I propose to renew with full length battens and 'standard reefing'
My first problem is how to fit a kicker, I suppose that I could use the old horseshoe thing but it was never much good. I had thought about making up a band which would go around the boom and be pinched up at the bottom where there would be a hole to attach the kicker. This solution would mean removing the band when ever I had to remove the sail.
Second question is about lazy jacks. I have studied various arrangements.I would like to keep my old (standard) boom cover. I feel that I could just secure the top end of the system about 12 inches out on the spreader (no real load on the system?) I guess that the vertical lines do not have to be especially tight under the boom so I could just lace the cover up as normal.
Whilst I am at it I might as well try for a third question!!. Am I right to go for the fully battened option? my boat is a (fairly ponderous) Colvic Atlanta (but dont tell her I said so!) will there be much benefit? I propose to try ordinary mast slides and reserve buying expensive wheely things as a last option.
Three questions, I know its greedy! I'm having to use the 'other side' for another set of queries!!
