charles_reed
What's the point of non-essential back-up? If it's non-essential, delete it.[/QUOTE][Then use the old HDD in the caddy for non-essential back-up.
Such brilliance - at least my irony was not wasted on someone -;-)
I will never ever buy a new laptop again.
AN SSD is certainly considerably more expensive per GB than a traditional drive (a quick search of amazon suggesting ~ 4x in the 512GB bracket, less difference as you go down in capacity) but how many people actually *need* 1TB of storage in their laptop? 256MB seems to be well under £100. Or there's the hybrid option at ~£70 for 1TB. Although the OP mentioned not really using it on board, some people will argue that on a bouncy boat there is a reliability advantage in them in the short and medium terms over traditional drives.
Regarding lifespan, my first two laptops I retired after 7 years after upgrading the memory as far as I could and a couple of hard drive upgrades each. The limiting factor was that people were writing more bloated software for newer whizzier computers. At that point I couldn't *give* them away to charities (too old/low spec despite having been high-end toughbooks when purchased). I don't play games or have significant computing needs either, and changing to linux was not an option as that's actually what I always did the day I got the thing home. Changing to FreeBSD perhaps.
To the OP, although changing hard drives is often one of the simpler tasks with a laptop (where the "hard drive isn't soldered to the motherboard as with the new breed of Apples), manufacturers don't make it as easy as they used to. Sometimes popping the body open can be fiddly. Sometimes there are multiple little film ribbons to be removed. If the hard drive bay is not trivially accessible, try googling your laptop and "hard drive replacement" to see if there are helpful youtube videos etc. Lay out all the screws in a logical order and have a decent spudger handy
Fan maintenance also often easy and earns you many brownie points from friends whose MacBooks have been driving them nuts for months.
Edit: other complicating factors: drive height: Not always the same. Fortunately if the drive is screwed into a caddy this shouldn't be a problem if the newer drive is slimmer than the old one. Older drives tended to be 9.5mm. newer ones, especially SSDs, should be slimmer. Also note that older operating systems weren't so good at dealing with SSDs. Someone who knows more about windows can probably comment more but a quick search suggests TRIM only supported from Windows 7
1Tb SSB £336 1TB HDD £40. I rest my case.
