webby
Active Member
Interesting figures... I noticed your top RPM was 4300rpm which seems quite low... Is 4300 your WOT RPM?
No, I have only run at WOT once very briefly and can't remember what the RPM was it was.
Hello,
Seems somewhat optimistic though the 855 all with fuel etc. is knocking on for 3tonnes.
Very suspicious of the "lean burn technology"! Seems more of a marketing catch phrase than anything different. All petrol engines are lean burn these days, it just means they use as little fuel as possible at any given revs. In the old days before accurate fuel metering most engines ran rich. I am very happy with the Yamaha and the 855 hull (without the Beneteau's air hull, which seems more marketing hype to me!).
Off down to Cornwall for two weeks on the boat so will update fuel figures.
It would be interesting to hear from an owner of such an engine
Anatares 8.80 300HP suzuki engine - Fuel used
Just read your latest blog and I have just completed a calculation of the fuel used over 112 hours this year.
We are often out with 9-10 people on board - night use - trips in all weathers - novice drivers wanting to get speed out of Romans 8! slow trips with the wife - sporty runs with the stand up jet ski - very much a full load up often, fuel, water, tender spare outboard motor - never out with less than 6-7 people on board with all their gear. we have a big family.
When we use it carefully I am pleasantly surprised on its economy, the art is to use the LEAN BURN rev band range to obtain the best fuel economy - Suzuki have clear guidelines - if you stay within the 3000 - 4600 range it planes well and gives great economy - brilliant matched power for this boat.
We have used 2,033.32 litres of petrol.
What a great time we have had!
It is better in a crowd!
Romans8 is the first uk owner:http://www.ybw.com/forums/showthread.php?306455-Beneteau-Antares-8-80/page5
Looks like about 4-5 mpg......
That's not quite right. I speak as someone who as their day jobs programs ECUs in performance engines, so hopefully my input is a little helpful.
Lean burn is a true and valid technology. Ordinarily you have to have a fuel mixture of around 14.7:1 Air:Fuel for efficient combustion that is known as stoich or lambda (at least in my circles). Normally this ratio decreases down to 11-12:1 for high load high output petrol engines (were talking 2-300bhp/litre/turbo) - the kind of thing I work with.
However modern common rail fuel injection has allowed another type of combustion.
Firstly its helpful to remember (for those that may not know) that normally a petrol engines use a throttle body (air valve arrangement connected to the accelerator) to control airflow into the engine and thus control the power it produces, as fuel is always kept around a fixed ratio. This differs to the basic diesel engine where there is no throttle body and output is simply controlled by how much fuel you inject. The problem with petrol engines is that for all the time your NOT at wide open throttle (WOT/Full power) there is a relative vacuum on the engine side of the throttle body. This causes pumping losses - and they are very significant in petrol engines. The larger the capacity the worse the problem.
By creating specific piston and cylinder head designs it has become possible to localise fuel combustion within a cylinder and thus creating localised spots where combustion is still efficient, but if you were to take the cylinder as a whole the ratio between fuel and air would be hard or impossible to ignite (were talking 65:1 ratios). The interesting thing is it allows greater efficiency simply by allowing engine power output controlling during say light throttle cruising, by fuel injection (Just like a diesel) and still allowing the throttle to be wide open - drastically reducing pumping losses - again like a diesel.
So a good lean burn engine offers significant economy savings at partial throttles compared to a similar engine being controlled by traditional methods. I would therefore expect mid range rpm from a Suzuki to be quite noticeably better compared to a Yamaha if Yamaha does not use lean burn technology. From Suzuki own material they claim 40% saving or so at mid engine loads compared to their older engines.
It would be interesting to hear from an owner of such an engine...
PS.. Saw the 855 at the London boat show. I thought it was great! Perhaps one day...![]()
At last got a few hours on the water this year.
Some initial performance figures for those as sad as me! Full tank of fuel, water tank, two people.
Total hours so far 10.5
50.7KNM
116 Ltrs (25.55 galls)
Averaging 2knm per gall.
Not bad.
Will update when run in a bit more.
Looks a lovely boat contemplating getting one myself but how do you find it manouevres in the marina as i currently have a single engined american sport cruiser without a bow thruster and find it it difficult to berth at times and were you worried about the reliability of a single engine ?
Hi, was there ever an answer to this? I’ve got a Saltwater II 17T-15.5 prop and struggling with poor mpgSorry to ressurect an old thread but I'm struggling to get the best performance out of my MF855 with the same engine. What prop are you running and what height is the engine?
Rhinoc
