New deck/escape hatch
Swanrad2
16 Aug 2005
Cheshire
We are replacing the foredeck hatch on our Centaur. The old one is horrid. The replacement is a Houdini and a little smaller than the existing so we are placing it in a teak frame and attaching that to the deck. So thinking about the best way of bedding the wood down (the Houdini will be bedded on a Neoprene gasket). The choices are:
1. Sikoflex (easy to work with, forgiving but messy
2. epoxy and micro balloons
Which is best?
Ta
Tony
30boat
N/A
26 Oct 2001
Portugal
I wouldn't use wood (even teak) for the frame.Much better to go to the trouble of making a fiberglass base glued and faired in with epoxy.That's what I did on my previous boat.Wood will eventually leak.
aquaplane
16 Sep 2006
West Yorkshire
www.utilitywarehouse.co.uk
This one:
http://scotland.boatshed.com/westerly_centaur-boat-164400.html
has a modern hatch fitted to a wooden replacement for the original manky GRP one.
Why he didn't just cut out the translucent bit of the old hatch and fit the new one to that I can't understand.
My point is, I find the extra couple of inches head room in the forecabin quite useful so would try to fit a new hatch at the level of the existing one, not flush (or nearly so) with the cabin top.
I would fit the new hatch to the existing one initially. I'd see how I got on with it and then epoxy the old hatch in permanently when I was happy.
Of course getting a piece of acrylic cut to replace the reanslucent pannel and fixing it down with some sticky stuff would work too.
Fantasie 19
23 Mar 2009
Chichester, West Sussex
Which is best?
Ta
Tony
Based on experience to date (minimal!) I would use butyl tape - been very impressed with how easy it is to use...
KellysEye
23 Jul 2006
Emsworth Hants
www.kellyseye.net
We had teak surrounds on all our hatches which were held by Sikaflex and screws, to fit the hatch Sikaflex was put on the teak and the hatches screwed down to the teak surround. The teak never leaked. Use tape around the teak underneath the hatch and around the bottom edge of the hatch where you would put your fingers to lift it.
Fantasie 19
23 Mar 2009
Even for bedding the wood down?
Never used Butyl tape, but I know it is the sealant of choice when you might need to move the thing in the future...
I can't think why not - especially as you're using a hard wood.. the reason I like the stuff is because it so easy to use... it doesn't smell, is easy to work, is easy to clean up, and doesn't get everywhere I don't want it to be, etc.... and removing stuff afterwards is just a matter of unbolting and then lifting fitting off....
