New cooker wanted for boat. Suggestions welcome.
I have Plastimo Neptune - 15 years old - Still going after replacing the oven pipe last year. Has Flame Failure device which is a plus. Oven seems to work ok for bread, pies, etc. Has separate grill which is another plus. The cookers itself is in fact made in England by a firm based in Bolton if I remember correctly. Spares and support are readily available.
JUST HUNT AROUND ON THE INTERNET FOR DISCOUNT CHANDLERS - BUT CARRIAGE CHARGE MAY EAT UP YOUR SAVING! WHATEVER YOU END UP WITH - AND PLASTIMO CAN'T BE FAULTED, GOOD SPARES SERVICE TOO - FLAME-FAILURE DEVICES ON EVERY BURNER ARE A MUST.
Re: Techimpex measurements pls.
Have just brought home my Techimpex XL3, 3 burner+ oven. height overall is 460 mm, but 425 mm if you take off the pan rest frame. Hope this helps. Width over gimbels is 530mm and depth is 485mm overall.
Sorry, don't agree. The 2-burner ENO I recently acquired is the most expensive, badly-designed piece of [--word removed--] I've bought in a long time. Put a pressure cooker on it and it heels to one side at rest! Add a few degrees of wind-induced heel and the thing's unuseable. Going back to my home-brewed 20-quid camping stove special...
Of the Plastimo >> The thermostatically controlled oven has a 1.25kw burner that will reach gas 200oC in around 10 minutes. The oven has a 25litre capacity
Of the Nelson >> The thermostatically controlled oven has a 1.5kw burner that will reach gas mark 8 (200oC) in less than 6 minutes. The oven has a 33litre capacity
There, I faulted it!
