new battery - recommended makes?
Birdseye
9 Mar 2003
s e wales
need a new 110aH boat battery. Nothing fancy, just an ordinary leisure battery. What makes do posters recommend? Lucas? Numax? Powerline? Varta? The latter seems about 50% more expensive.
Plevier
22 Aug 2008
Brighton
Interesting to note that Battery Megastore call this a deep cycle battery but its manufacturers Atlas BX in Korea call the XV31 a starter battery! Their cycling range is the DC series (also sold by Bat Mega.)
See http://www.atlasbx.co.kr/eng/product/product_list/Product_View_ST.do
When I was in the battery industry quite a while ago I reckoned I knew who made the good ones but now with so much less European production and more from Korea, China and Taiwan in most cases you don't know who has actually made the product despite the label. (The Alphaline range is an exception to this; Atlas BX declare Bat Mega as their UK distributor and http://www.alphalinebatteries.co.uk/buy.html carries both names. However the Korean website doesn't list the XV110 that Batt Meg sell as Alphaline.)
You used to get a lot of variation in weight too that was a good indicator of quality; now if you pick a particular size they all seem to be the same weight. I have to get the XV110 because of limited height. All the ones I could find, including Varta which used to be a reliable top name, are 24kg except the Exide gels originally fitted which are 28kg but a silly price and i wouldn't use gel anyway.
Tayna sell 2 supposedly different qualities of Enduroline and Powerline with different warranties at different prices but they weigh the same. I'd bet they are the same; we used to do that for Unipart - different prices for different warranty and different colour of box, insides were the same.
Lucas is just a brand name and I'm almost certain the same product as Numax and some others. Actual manufacturer unknown; there may well be several and they may change frequently.
So now I regard them as interchangeable commodity products. I bought the Alphaline in the end.
Of course it's a different ballgame if you lok at Trojan, Lifeline etc but not justified for occasional weekend use. "Leisure" batteries although technically cr*p are the economic solution.
savageseadog
19 Jun 2005
My thoughts on batteries in boats is to have two (at least), one a normal diesel engine automotive battery and the other a deep discharge battery. Use each battery for the purpose it was made for.
[3889]
26 May 2003
Ignoring other variables, which is to be preferred, sealed or open? I've looked at Alphaline DC24s but am put off by not being able to top them up - I add water to my current batts every two months or so.
As I understand it sealed batteries have a pressure release vent. At what level of charge will this operate?
Plevier
22 Aug 2008
Brighton
Yes, but don't kid yourself any "leisure" battery - or anything priced like one - is really a deep discharge battery.
If you mean what you say, you must use something like Trojan for wet or Lifeline for AGM. As I said, that's a different ballgame.
If you are liveaboard/blue water, fine.
IMHO not the economic solution for occasional weekend/short cruise use.
I do agree about starter batteries - why do people use anything other than normal starter batteries if that's the only duty they are doing :confused:
savageseadog
19 Jun 2005
Don't worry. I'm an electrical/electronic engineer. I'm not a believer in leisure batteries which appear to be a compromise between starting capability and deep discharge capability. I like the post that mentioned battery weight as an indicator of quality. It is.
Plevier
22 Aug 2008
Brighton
You are confusing two types of battery.
"Sealed maintenance free" such as the DC24 is just an ordinary wet battery that will not need topping up in its lifetime if charged according to certain conditions. It's really just marketing making use of the effects of improved modern materials such as lead - low antimony and lead-calcium alloys. The battery is not technically different other than the liquid level may be a bit higher. If you use very aggressive charging - roughly speaking anything above 14.4V routinely - you may indeed lose too much water. Many of these batteries (I don't know specifically about the DC24 but the pic looks like it may) have a cover strip over the original filling ports, often under a label, that you can lever off and top it up; they just don't have the old style screw plugs. However some do have sealed on covers, then you have a problem. These batteries don't have pressure relief valves.
"Sealed lead acid" also known as VRLA and AGM are genuinely sealed with a pressure relief valve, do not have free liquid acid in them and cannot be topped up. However if correctly charged they do not lose any water or gas, internal recombination reforms the water during charging (and the energy appears as heat). The pressure relief valve should only open in the case of serious overcharging (some may gas a bit early in their lives before reaching equilibrium).
Plevier
22 Aug 2008
Brighton
sailorman
21 May 2003
Here or thertemp ashore
