TerryA
Active Member
I recently had to replace my fuseboard when the 40 year old original started to deteriorate. Positives were easy enough to swop over but the old board refused to budge despite me removing all the obvious screws. It turned out that it was secured by a number of neutral cables fixed to the back which became disconnected when I levered it off. I did some reconnecting and with the exception of the radio and the engine heater plugs things worked.
Can someone explain in simple terms please:
Why the radio just makes a blipping noise and doesn't turn on?
Why if the first, second and fourth positions on the ignition switch work but not the third?
Why I can't just connect all the neutrals together, if I do nothing works?
Help for the bemused gratefully accepted.
