Neting
escape
9 Apr 2002
North West England
ToMo,
dont under-estimate the amount you require or the length of time it takes to fit when trying to ensure all the diamonds are the same size/shape.
You will also need a good quantity of cord to secure it to the guardrail and toerail (assuming you have a perforated toerail).If not you can tie a line between stanchion bases to use as a bottom fixing...
probably telling granny how to suck eggs ..?
escape
9 Apr 2002
North West England
To be honest i havnt used netting for about 10 years and only my wife had the patience to fit it well.
From memory start at a vertical so if your pulpit/pushpits slope go to the nearest stanchion (leaving enough spare to go back to the slope).
Do a rough fit using short ties at fixed points as this saves threading and unthreading your final cord.
If i think of any thing else i'll drop a post.
ChrisJ
12 Jul 2004
Newbury, UK
Tieing the bottom of the netting to the toe rail all along might look nice when you fit it, but it is a pain once you land alongside someone and need to use a spring or centre cleat.
Even if you have a perforated toe-rail, I would still rig a line between the bases of each stanchion, just so you can get ropes etc. underneath it.
Buy some 3mm Kevlar or similar - as this has the strength and lack of stretch needed to get the bottom tight. Feed this through the bottom of the diamonds, and tie tight to the stanchions.
