Need to service winches. If I use white spirit,should I wipe it off or air dry
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
I need to service the winches. I have 7. Hopefully I can do this on a nice sunny day (in Corfu in April).
I plan to use white spirit to clean (yes I know I could use diesel, WD40, brake cleaner. kerosine, lighter fluid)
My simple question is what to do with the bits once I have de-greased them - before reassembling and re-greasing? Can I dry off with kitchen paper or do I have to use "lint free fabric"? Can I let them air dry? Does it matter what I do?
Thanks for any advice
TudorSailor
Not sure I'd bother with all that mucking about. Just wipe the old grease off onto some kitchen roll, whack a load of new grease on, and put them back together.
I clean mine with paraffin because that's what I have and leave to air dry on newspaper before greasing lightly, oiling lightly and re assembling. A toothbrush is useful for removing accumulations of grease.
I use paraffin plus a toothbrush to get in the gears, and wipe/leave them on some kitchen roll when moving onto the next component. Need to take a little care with the ball bearings as they tend to pop out when wiping with kitchen roll (at least they do on mine).
Just done mine the other day , , I used white spirit , in the med sun it didn't take long to dry .
As far as wacking on a load of Grease has suggested , I wouldn't unless you want it to run out all over the place as soon as it start getting hot , just smear lib amount on the shaft and bearing and oil the paws .
By the time you've rubbed on a thin layer of grease to the components (except the pawls of course) it probably doesn't matter.
I use variously diesel, parafin, WD40 or white spirits to clean the old grease off, depending upon what's convenient at the time.
use white spirit - place on something absorbant then let air dry.
on;t whack on grease. It should bea very light coating!
Anything more than a light smear and, particularly in a hot climate, grease may find it's way into the pawls as happened on our Lewmar 48's. It's unnerving when your self tailing winches start going backwards!
