oceanfroggie
Jon, I think you need to check what type of battery charger you have installed. If it is a "smart" charger, one which charges depending on the state of the battery, then this should be OK. If not "smart", then you may kill your batteries quicker than you would like. I am assuming your fridge is 12V, and running off the batteries? My worry is that you are leaving something on, and assuming it won't fail while you are away.
Many smart charges can't detect a dead or weak cell in one of the batteries in a series or parallel pair, therefore over charging and boiling off the water in the good battery (e.g. two or four separate batteries connected together for a domestic supply)
