spurnclass
Would very much appreciate an answer to the difficulty I encountered yesterday as described below.
This year, I have been forced to replace my BMW 8hp diesel engine with a Honda 10p outboard mounted off the stern with a outboard bracket.
The outboard bracket has "slots" which allow the outboard to be positioned in the water at various different heights. I have been having some difficulty deciding the best height to use. At first, I utilized the farthest "down" position. This meant that when running a very low speeds in the harbor the outboard seemed to be at at very good height out of the water. But I started noticing last week that when running at 5-6 knots at just under full throttle the outboard seemed to be very low in the water. At no time would the head be submerged but only around 2-3 inches of the shaft would be above the waterline, and the point on the shaft where the cooling water is dispelled was probably at or under the water line.
With this in mind, I decided on my trip yesterday to raise the outboard much higher out of the water. At very low speeds in the harbor a great deal of the shaft was exposed, but at cruising speed I was much happier with the position of the outboard in the water. At cruising speed you could now see the coolant water being dispelled and dropping down to the water. A least a foot of the shaft was exposed, but the exhaust still well below the water line. Everything was going fine until we reached the very end point of the River Deben, past the horse sand at Felixstowe Ferry. We decided to pick up a Buoy just before the final red buoy which marks the end of the river, to have a break and a spot of lunch before crossing the Bar. The tide was flowing very heavily against us and wind was gusting maybe 4-5 straight over the bow. I decided to slow down to drift against the tide onto the buoy. I reduced the throttle on the outboard accordingly. At this point I realized that I had reduced throttle far too much and we were drifting backwards with the tide far far too rapidly for my liking. We were being carried towards the Baudsey side river bank, the depth was rapidly falling away. Very unfortunately we were also heading straight for a moored yacht (with skipper and crew on board watching). My immediate reaction was to apply full throttle to punch back into the tide. But to my horror the outboards propeller was now clear of the water and was having absolutely no effect. Even at lower speeds the propeller still wasn’t getting under the waterline. With the Baudsey shore rapidly approaching (thankfully we missed the moored yacht by about 3 feet) I reacted by turning the boat through 180 degrees, leaned over and pushed the outboard down into very lowest position on the bracket. I was then able to get control of the boat once more, altered course to the horse sand buoy and made for a prompt return to Woodbridge with my tail very much between my legs! (I didn’t fancy going over the Bar after the incident just experienced.)
That’s the story, here are the questions.
1. With me positioning the outboard higher in the water, I experienced absolutely no problems at low speed or at full throttle all the way down from Woodbridge to Felixstowe. What I cant understand is what made the outboard behave the way it did when we arrived at felixstowe ferry. Is it related to the tide/Waves/Wind?
2. What recommendations could you give as to what is a sensible height to have the outboard out of the water at? Is there any rules of thumb etc to base it on?
Thanks as always for your exellent help.
James
<hr width=100% size=1>Anyone got any info on 'the spurn class' yachts, 23ft GRP built by marine plastics in 1970-ish?
James
