navtex
baggypipes
5 Oct 2006
anywhere the wind takes us
freewebs.com
hi any advice welcome.
We are trying to reprograme our navtex pro +. we follow all the instructions ie select the stations we require, however a warning keeps comming up that'nothing is selected' it apears it does not save what we put in. It worked fine till navtex went down upto 30 june also our aerial pulled out. We know others are working so no probs with reception. now at a loss. thanks.
I don't believe the aerial has to be plugged in to enable the device to save channels - I only say this because I had a dodgy connection a few years back and it made no difference apart from the graph showing no signal.
I assume you get a long list of letters for the stations and make the station you want into a capital letter? Same for messages.
Might be worth calling Nasa incase there is some sort of reset.....
Sorry I can't be of any more help
there is a restore to factory default option, although I can't recall the key combination right now. Its in the user booklet though.
