NAVTEX
Philiz
23 Aug 2008
Staffordshire Moorlands U.K.
www.shabiera.co.uk
I'm thinking about putting a Navtex receiver on the boat. I know there are self contained units with own display, and units to connect to your laptop. But I've noticed they do a Navtex engine unit specifically for connection to a Raymarine C or E series. Does anyone know if there is a unit which I could could connect to my Garmin GPSMap 4008?
You dont need Navtex on the Menia Canal....... do what I do! phone Major and ask for a weather update. :)
Tom
Yes, but you never bother to check where I am when I give it to you.
Weren't you suspicious when I said it was 33C and thundery.....in January?
Phil, there is no way you are going to fit another piece of equipment in that tub, at least not before you jettison an animal* or two.
*Disclaimer. Not necessarily to include a wife.
Weather forecast? In the Strait? Ain't you got no windows in that shed of yours Philiz?
You can get BBC inshore/ coastal & shipping forecasts (plus 5day tides for any location) on any web enabled phone - if you don't drop it in the water like I did at the weekend.
Has anyone got anything good to say about Navtex?
Navtex is a good system when used correctly. Remember that it is a system giving forecasts and other information on fixed time slots from various transmitters and you select the ones you want to receive. This means that the forecast for your area might be sent out nearly 4 hours before your ETD and so it is best if the Navtex is running prior to departure. Best of all is running all the time. Taking this into account you either need an engine which stores at least a day of messages or a system which does this so that on arrival on the boat the forecast is there.
It is no good switching on as you ring stand by main engines and send swimbo forward to cast off as you will be in the eye of thee storm by the time Niton Radio dings your dong :).
There are several display units that store as required and I expect someone will share their experiences. I favour the Furuno but others may like the lest costly items with bigger screens. Just note the stand by current as if left on that is draining your battery.
I've got it on Seafisher, it came with the boat. Interesting to play with but never used it in anger. Too much information to scroll through. Maybe I should set it up for a more localised area.
It's brilliant if you use it properly... and **** if you don't.
Like any electronic gadget it will do exactly what you tell it to. So if you tell it that you want information about rig movements in the North Sea, it will give you them -- if it possibly can -- even if you are in Wales and thinking about a trip to the Scillies.
The commonest problems are:
when people leave it on its default settings (which is usually all messages, all areas)
when people can't wait for it to receive anything, but switch it on, then look at it ten minutes later and say "it hasn't done anything: it's a load of junk"...
... and then when it does receive something they say "Oh I can't cope with all that: it's a load of junk"
Set it to cover only the area that you are interested in, and only the messages that you are interested in, and then leave it switched on all the time from when you first get on board until you get back in the car to go home. So long as you leave it switched on, it's like the French resistance girl in 'Allo 'Allo -- it will give each message only once (but it will store it so that you can read it as often as you like.
Dare I suggest Navtex is effectively redundant technology for most leisure mobo's. The money would be better spent using a smart phone such as HTC desire or iPhone for up to date detailed visual weather information including wearther radar, wind, sat images, synoptic charts, sea area forecasts, etc. IMHO, internet has replaced the jurassic technology that was navtex. Naxtex is the marine equivalent of telex - soooo 1980s :) Worse still get an iPad, now this will really upset some traditionalists.
'Ang on, I suggested an Internet enabled phone about 10 posts ago! It's cheaper, quicker but can only be used fairly close inshore - like at the start of your trip, before leaving the marina or when at anchor.
And stay within 10 klicks of the shore!!!!!!!
