Navman wind speed
I,ve just repaired a 3100 wind instrument by dismantling and padding out the LCD contacts strip. There is a flat multi contact braid which seems to be pressed against the LCD with a clear flat piece of plastic. I think the problem was the pressure reduced over time. I bought some very thin adhesive foam and stuck it to the back of the clear plastic and re fitted it. seems to be working fine now. while I was at it I also treat the pub with lacquer and re sealed the clear plastic window joints with superglue. Fingers crossed all working ok now. Watch the lugs as you dismantle it. I broke one and had to glue it back into place. I have to do the depth and speed yet. I'm going to see if I can apply the same trick.
