Navman transducer
That shouldn't be a problem as there are brand specific in-hull kits and universal kits available.
I'm currently using the Airmar, bonded to the hull and filled with antifreeze:
Anyone know what depth sounder/transducer will work with a Navman display?
Don't spend too much on the transducer, from personal experience and reports from others it is unlikely that the Navman depth head will prove reliable, these units are all now old. I started with a set of wind, speed and depth from Navman. The log has had to be replaced (with Advansea ) and the depth works unless there has been high humidity or rain when internal moisture affects the display. Segments of the digits do not display making guessing whether the depth is 7.1 or 1.1 rather embarrassing .Leaving the instrument on with the internal light on full eventually clears it but it is unpredictable.
