changeman
I intend to dry out at Isleworth alongside Church Street and would appreciate some local knowledge.
We have an 18 meter barge and when coming downstream at high water should not have a problem.
However, when coming off the mooring on the rising tide, we could have problems with the flow of the stream.
Barges, being flat bottomed, are not the easiest to turn round as they always go sideways.
So, if I am moored facing downstream, I could warp the bow off and when pointing in the right direction, engage forward gear.
The tide could then sweep me sideways, right into the front of the adjacent island, or push me up the side channel.
If facing upstream, I may have problems turning fast enough to get into the main channel and find myself again in the side channel.
As this seems to have a 90 degree bend at the far end, any fast current would take me sideways into the boats moored there.
Questions:
1. How fast is the stream likely to be when I get water under my flat bottom?
2. Which is the strongest stream - the main or the side channel?
3. Question for experienced bargees - how would you get out of there?
Thanks in advance.
Questions:
Thanks in advance.
