MagicalArmchair
The motoring nav lights on my pulpit I noted hadn't been working since my deck repaint. I assumed the terminals were corroded on the bulbs, so got to work cleaning them up one evening on our summer cruise. Tried them again after cleaning up, and no luck. I went below and took a look at the fuse, and boom, noted it had blown. I replaced the fuse, and snap, the lights dimmed for a sec, and the fuse blew again. That fuse just juices up the two nav nights on the pulpit, port and starboard. If, from the appliance side of the fuse, I disconnected the green starboard wire, the fuse no longer blew. If I unplugged port, and plugged back in starboard, the fuse would once again blow.
From the pulpit I unplugged the nav light, (fearing the light unit had a problem), replaced the fuse and the fuse STILL blew. Out of time by now, with the 1st mate accusing me of waking up our daughter sleeping in the fore-peak and it was time to come to bed myself, I grumpily gave up my fruitless diagnostics.
The below photo is directly under the pulpit in the anchor locker, the chocolate block attached to the ceiling. The green (starboard!) wire in the below, goes all the way back aft to the bottom of the fuse that keeps blowing. I can see in the below, the green wire looks corroded where it enters the hateful chocolate block. Do we think this could be the problem? My eletrickery skills are somewhat limited!
My next step is to replace the chocolate block and inspect\cleanup the wires here. Any other suggestions for diagnosing the problem?
