tasweljade
At some point none has to think about NOT replaceing parts for an obsolete system such as navico corus and replace with a whole new system... Yacht is in USA where simrad is not supporting the system and has no parts - there are a few in UK but very limited
in My maybe soon to be removed corus system
I have depth, speed/temp and wind transducers(wind is only 6 months old)
a c400MB multifunction dislay down below (checked last april in Florida and proved 100%) This is unit that the transducers for depth and speed plug into and single cables leave from.
a C500W analog wind display (LCD doesn't display any more, rest works fine)
two C700DC multi function displays, work fine, look fine
a nema 600 interface box behind nav panel so I expect this is dusty but fine.
The displays all look fine/perfect and work fine with the one exception I mentioned. The 4 sun covers all look a tad sun damaged but that's what they are there for.
The depth transducer is plastic and has been stuck inside the hull, it's removable but will look like it's been glued down with silicon
The speedo transducer is maybe 3 years old, the tru hole part I would keep, BUT I think I may have a extra blank thruhull
The wind transducer has been up on the mast since april 2004 only and I have an unused new mount for it. also have I think spare used cups and wind vane.
any interest/advice
any interest/advice
