Navico Corus Instruments
GeorgeLlewellin
19 Nov 2006
Pembrokeshire, UK
Wanted used Masthead wind transducer Model ATM 600, for Navico Corus C 600 or similar, any condition. These units are no longer available through the trade. Also does anyone know where I can find a wiring diagram for this unit, our system was working fine until the stem was broken and the wires parted.
Thanks George
George there is a Wnted section a bit further down the main menu page, this should be in there. I will get the moderators to move it for you.
Welcome to the Forum....
Jim
...our system was working fine until the stem was broken and the wires parted.
Isn't it possible to repair it then? There are probably only 4 wires, can't be that difficult to reconnect them.
If you look at the printed circuit carefully, you may find that the + and - power connections are marked, failing that you may well be able to work out which they are (or a knowledgeable friend perhaps could). That only leaves the NMEA wires.
JGtech of Weymouth had some spares for the Corus range and are most helpful. (I removed a complete set from my boat during a major refit earlier this year and sold them on ebay) There was another company around Portsmouth that do repairs - if I can find the name I'll post it up here.
There are four connections, two power and two for the CAN bus connection.
As you look at the pcb with the main chip towards you and uppermost, the centre of the PCB should be where a lot of wires come together. The connector line of four is where the wires connect to, then from the LHS they are red, black, white, green
I have a PDF diagram of this if that would help.
