NormanS
I mixed oxalic acid with wallpaper paste.
Any benzalkonium chloride based mould and mildew or patio cleaner will do the job effortlessly
eg
Patio Magic , which is widely available
Wet & Forget, from Screwfix and Robert Dyas etc
Barrenttine Knockout Mould and Mildew Cleaner, from Toolstation
Good for killing algae on ropes etc
AFAIK safe on hoods and covers etc but always test on a corner if in doubt.
There has been talk of industrial jet washes of very high pressure and osmosis.Personally I won't let a jetwasher near my GRP decks, and using one on teak is a hanging, drawing and quartering offence. Moulded non-slip patterns on GRP decks are almost inevitably resin-rich, so more brittle than a flat moulding like your hull, and jetwashers can knock bits of GRP off. They are also remarkably good at finding (possibly by creating) deck leaks around windows/hatches etc.
Patio Magic or other benzalkonium chloride based product followed by local oxalic acid for rust stains. Then after each works hose off with a softish brush.
What type of wallpaper did you hang?I mixed oxalic acid with wallpaper paste.
Grunt, mentioned at the top of the thread is perfect for this. Premixed as a paste that stays put. We recently used it on our waterline while afloat and it’s by far the best product we’ve ever used.Oxalic acid or an oxalic acid based cleaner such as Y10 will remove those.
Marine Bazaar in Plymouth sell it, as do some fibreglass suppliers.Thanks, it says its a regulated poison but available for business use, and not that expensive for 1 kilo. Cheers
Seawater...Sorry ….. it is GRP …… I have never used patio magic - small areas only or the whole thing ??
Yes, we only get the green, and plenty of it, when ashore for the winter. Dirt and mud at any time.Once you have cleaned the deck, regular dowsing with sea water will keep the green mould away. Rain and freshwater washing will not stop green mould.
I am thinking the following (it is pretty bad) ...........
1. Jetwash
2. Scrub using Ecover washing up liquid.
3. On stubborn areas, use oxalic acid/Y10
4. Jetwash again.
Does anyone have any better suggestion ? ............ many thanks![]()
I brush it too.Yes, Patio Magic works brilliantly, on decks and canvas alike.
Personally I to brush on rather than spray on, my be wrong but feels less risk.
I left a lot of pavement-de-icing salt (some of it in old socks and tubs, some just scattered) on the heavily vegetated deck after scraping and scrubbing with Fairy liquid. A year later it hasnt re-greened much.I brush it too.
