NASA Target Navtex standard plus. Q's (2nd try)
jimbouy
21 Aug 2003
Sailing.. Solent. Home..Bucks
www.bluemoonlight.co.uk
NASA Target Navtex standard plus. Q\'s (2nd try)
The forum seems to have lost my first post.
I have picked up at very reasonable cost a Nasa navtex unit that is described on the box as a standard plus, and comes with a plastic stub aerial.
I am wondering what makes it a plus unit as the instructions are the same as the standard.
Also can someone tell me what station letter Niton is on as I think the id's in the manual may be out of date.
And before anyone tells me to ask Nasa here is the email reply I got.
"It could be dual frequency, it certainly has editable menu programming and
scrolling is possible whilst receiving a message."
<hr width=100% size=1> "It is a pleasure to give advice, humiliating to need it, normal to ignore it"
Jools_of_Top_Cat
16 Dec 2002
Re: NASA Target Navtex standard plus. Q\'s (2nd try)
If it is dual frequency and the key operations are the same as the clipper then ;
If you press ctrl+enter together it should switch between nat stby and int stby. Although you would I assume need to have the correct aerial to provide dual frequency. The nasa units do not dual watch automatically.
I was having real problems getting any decent response on my clipper navtex with the aerial at deck level, when my mast was stepped I fitted it to the masthead extending with 75ohm coax, it is working a treat, prolly not the hieght but being away from electrical noise.
Hope this helps....
<hr width=100% size=1>J
<A target="_blank" HREF=http://www.topcatsail.co.uk>
</A>
