morgandlm
I was experiencing intermittent failures of the paddle wheel operated speed readout last year when the indicated speed would drop to zero and only sometimes re-start. I put this down to a fouled wheel but the problem has continued this year (with a clean hull and paddle wheel). I have discovered that waggling the connection at the back of the instrument when underway will always restart it. Despite cleaning the contacts to try to ensure good continuity, the problem continues. I could send the instrument back to NASA to test but before doing so would like to test it myself. A simple test can only be achieved by being underway or by manually spinning the paddle wheel in which case I can't be at the instrument. I want to find out whether the fault is the instrument, the cable or the connection.
I assume that the paddle wheel sender simply sends a series of pulses which are counted at the instrument. I propose to use an Arduino to produce a series of 5v, low amperage pulses to test the instrument. Will this work? Can anybody advise what form the signal takes from the paddle wheel?
Any advice welcome
David Morgan
Any advice welcome
David Morgan
