IanScrim
Just had a terrible day trying to get my PC NAVTEX PRO MkII with the serial port connector working with my new Windows 8 PC which only has USB connections.
The latest Prolific USB to Serial drivers failed to load and Device manager came up with a code 10 fault.
Eventually I found a solution at
http://social.technet.microsoft.com...46131/prolific-comm-to-usb-driver-not-working
see text below
I found the 3.2.0.0 driver at
http://hamcoach.blogspot.gr/2013/09/prolific-3200-driver-guide-for-widows-7.html
And then finally
The Navtex program needs running as an administrator
Hope this saves somebody some time and grief!
Text from site copied below
"No need to copy files to the drivers directory, etc. at all! I got my PL-2303 USB-to-Serial-Converter running on a 32-bit machine with Windows 8 as follows. My Windows 8 installation is in German, so I have to translate.
Go to the device manager and plug in your USB-to-Serial cable. The device icon should pop up in "COM & LPT" with a yellow mark that indicates that the device is not correctly installed.
Double click to open its properties.
Go to the "Driver" tab and hit the button to update your driver.
I see two options "Automatically look for new drivers" and "Look for drivers on your computer". Choose to look on your computer.
Now you may specify a path to look for drivers. Leave it blank and choose to select a driver from a list of drivers on your computer.
On my computer it shows four different "Prolific USB-to-Serial Comm Port" drivers. Choose version 3.2.0.0.
The driver version 3.2.0.0 [31.07.2007] works fine on my Windows 8 32-bit installation, while the newer versions of the driver (3.3.5.122 and 3.4.36.247) do not. Hopefully, this helps someone out there. "
see text below
And then finally
