Alfie168
My NASA LED Tricolour Light took a rather prolonged swim in sea water, for reasons I shan't bore you with. Well I took it apart today and cleaned it and found that every other LED still works. More than that I found the faulty white LED that was preventing the other circuit working, so when I short it out all the LEDS still work just fine...except the rearmost white. Oh Goodee..thinks I
Now I can easily bridge the faulty LED, but have an inclination to solder in a new one. Does anybody have any idea what spec to look for when I buy an LED to solder in, or do I just wander into Maplins and ask for a "bright white LED please". They seem to be operating between 3.2 and about 4.5Volts depending on which one I test when powered from a 12 V battery.
I also need a new glass dome for it as the old one got badly abraded on one side by the sand when it was submerged. (Don't ask) so I will ask NASA if they can supply, but I suspect the answer might be no, so if anybody has got an old non working NASA Supernova I can scavenge the dome off..that would be nice.
Tim
Tim
