erbster
Anyone know the type of fuse needed for the NASA BM1? Can't see a rating on the fuse and no reference made to it in the manual. It's not a type I'm familiar with- is it a special type?
The BM-1 draws 3mA and the fuse in question is a 20mm glass fuse with a rating, as VicS quite rightly states, is a 1Amp standard fuse.
If you unscrew the black fuse holder and look very carefully on the side of one of the end caps, you will see the code "F1A250V". It is a standard fuse.
As I understand itThanks for the advice chaps. I saw the code, but didn't know what it meant. The manual mentions a 1amp fuse for a starter battery connection (I don't have one), but not the fuse from the domestic battery. Advice about changing the fuse holder also noted.
