niallw
I've got a NASA depth, wind, speed log setup. Ive learned to live with the broken windcups and fouled speed/log if only I could get the depth sounder to work reliably.
It sometimes reads OK up to about 8M, otherwise display E, or go blank and flash ---, other times in deeper waters it will jump around with random readings.
How to fault-find, any ideas. Do i replace the transducer itself or the viscous oil. Could the wiring be at fault.
Ive read on some other threads about hull thickness being an issue for these in-hull transducers. The GRP in my Nic 26 is around 3/4 to 1" thick. Im reluctant to put another hole in her for a through hull model, any other suggestions.
