MikeFloutier
I like your idea of switching the navigator off when tinkering with the wind transducer connections; it might even be good to disconnect the navigator from the autopilot temporarily.
Then, the first thing to check is that the blue NMEA 0183 - wire on the tp32 is connected to the negative battery wire that goes to the NASA wind. It is this connection that forms the circuit allowing the data current to flow from the NASA to the tp32.
Also, can't remember if you already mentioned this but, apparently, you can calibrate the NASA unit by fixing the direction sensor in the straight ahead position and then just shorting the data wire to ground (i.e. Battery negative on the NASA supply). Having said that, if the tp32 is anything like my Raymarine st2000, you're not interested in the absolute wind direction, only the shifts, so I can't really see any point in calibrating the NASA kit.
