Nasa Clipper Depth Question
apollo
12 Sep 2003
Thames
Have just fitted a Nasa Clipper Depth Sounder, the unit comes up with "OUT".
I am not sure whether this is as obvious as it sounds ie it because its "out" of the water (which it is!) or because there is something wrong with the transducer connection?
The manual is unclear and says check the transducer.
Does anyone know?
hlb
RIP
Any Pub Lancashire or Wales
In any event, it wont work out of the water and you wont know till it is in the water.
<hr width=100% size=1> <font color=blue>No one can force me to come here.<font color=red> I'm a volunteer!!.<font color=blue>
Haydn
poter
4 Feb 2002
Still going south currently in Corsica for winter
www.fairhead.com
What you can do as a test is get a great glob (technical term) of vaseline and place your transducer on it, in the place you think you will finally locate it...presumably in the bilge somewhere. & go for a trial run it should work ok.
when you are satisfied then you can epoxy in permanantly.
poter.
MickJ
25 Mar 2003
Essex, Crouch.
How did you fit it? I used to have a 'factory fitted' Clipper transducer on a new Shetland boat, that read "out" most of the time whilst in the water cos it was poorly fitted (just a blob of Vaseline in a tube). I bought a NASA oil both fitting and it worked perfectly from then on. Also be careful of where it is fitted cos it wont read through a cored hull (they also fitted it in the wrong place incidentally...).
