NASA BM1 battery monitor
bromleybysea
10 Nov 2007
Not Bromley anymore, yippee!!
my BM1 battery monitor seems to have developed a confusing fault. It always shows "charge" even when there is no charging taking place. It appears to show accurate voltage when being charged but then seems stuck at a resting voltage of 12.9 with the bar graph permanently showing 100%. I have recently fitted new batteries-160ah of AGM- and gone through the reset procedure as per the manual. Finally, when I turn on the illumination the amps display rapidly climbs and the volts display drops to 12.3. Any suggestions welcome!
CJ13
10 Jan 2008
Have you checked the connections to the shunt / batteries?
When my BM1 display was clearly wrong, a good clean of the conns sorted it.
