truscott
I have a single 120 watt Kyocera panel set up temporarily at the moment. Output goes via a 30Amp PWM type controller. With the sun shining at the moment, the display on the controller shows amps out of around 5 Amps but the BM1 shows half that.
The output from the controller is connected on the correct side of the shunt ie the positive wire goes to the positive post on the battery and the negative to the same side as the yellow wire on the shunt. There are no connections on the other side of the shunt other than the black and white BM1 cables and cable to negative post.
The controller is only a couple of feet from the battery bank and the wire is the same gauge for both in and out (sadly I''ve forgotten what gauge, but the outer diameter is 5mm and at a guess the actual core diameter is 4mm).
Curious to hear what folk think could be the cause of the mismatch. Voltage drop over such a short distance seems a stretch but am happy to be proved wrong.
Cheers PT.
Cheers PT.
