NASA AIS Engine testing
Praxinoscope
12 Mar 2018
Aberaeron
My ‘new’ boat is fitted with a NASA AIS Engine connected to a Garmin 540GPS . As our home waters are in a relatively quiet area for large shipping (Cardigan Bay) we don’t get many ships transmitting an AIS signal, so I am having difficulty in working out if the AIS/Garmin set up is actually functioning. Apart from sailing 30 miles down the coast to wait for the Irish ferry to leave Fishguard and pick up their AIS transmission can anyone suggest a way of checking if the AIS is working?
When I had one, many years ago I got a test bit of software from NASA, but my engine was running on a PC.
Two sources come to mind, one a local yacht with a transponder through a club (surely one exists locally), and two, the local lifeboat might have a scheduled trip (i assume they have transponders and am not suggesting you summons them).
Oh that level of paucity might exist in the solent.....
Hi Blan321
Thanks for your suggestions, I think the lifeboat might be the best option, we usually know when they are out on practice.
I can sympathise with you on density of traffic around South Coast, but envy you the numerous harbours and anchorages.
Praxinoscope
The little green ED under the power LED flashes when a message comes in, so if you see that flashing then you know *something* has come in. It also sends a test message when you turn it on though with no lat or long it might no get displayed on the garmin.
Hi GHA
Thanks, the tip that the AIS sends a test message when switched on is useful, we have so little AIS activity in this area I could wait weeks for the green LED to flash with an incoming message.
Look out for the CG helicopter based put of Caernarfon as another AIs source. I have tracked it over 40 miles away. It's height plays a great advantage for reception. . It happens to use our home port as a way point. I believe one pilot lives in the village! Open CPN has a brilliant display for it unfortunately it shows as a green fixed wing plane icon!
Hi NorthUp
Thanks for your suggestion, have tried both sites and they just confirm the absence of AIS in our area, nearest AIS signal is Fishguard (Irish Ferry) 30 nm away. Aberporth traffic (12nm) may occasionally transmit AIS but not a regular event.
Will talk to NASA and see if they can suggest something, it would be nice to know it’s working before sailing over to Ireland later this month.
Praxinoscope
