smithy
Why do you want an angle grinder on a pole?- If anything that sounds b..dy risky
Come to that i do not think I have ever seen one, but learn something every day:encouragement:
I wouldn't really use an angle grinder on a pole but the glassed over nuts are hard to remove at that distance.
Rogershaws idea about grinding heads off would work although all countersunk. The remains of the bolt could probably be knocked through taking with it the glassed over nuts. Just to complicate things a bit further there is also a welded strap on the running down the bow, nuts all glassed over of course! Probably just easier leaving the plate in place, or squashing a shackle
And thanks Daydreamer just trying to visualize your idea.
