capnfishy
This is just another example of Great British intolerance, let's call it 'boatism'
Unfortunately no side decks to facilitate easy crossing of vessel.
Usually a fender the width of a supermarket budget sausage or none at all protecting your pristine immaculate shiney Gelcoat.
All deck furniture designed to fasten warps the thickness of thin cotton
A small verdant jungle on the roof to make standing on it as difficult as possible.
...and worse of all a plethora of poorly executed badly painted cartoons purporting to depict some mythical Avalon of barge existance when actually people actually suffered a short brutal and very hard life and would have given their eye teeth for a comfy warm dwelling ashore..![]()
Sometimes a narrow boat being on a mooring can be an advantage.
I exercised the "advantage rule" outside Tesco in Reading in august this year. I came through caversham lock downstream knowing that there would probably not be space to stop and shop at the tesco as it is generally full of that which shall not be named.
Anyway there was a narrow boat there which had a moor alongside sign. So I did. My boat is a relatively big (in upper Thames terms) barge.
Anyway, bloke on board was cool and it was easy to disembark the ladies across his stern deck (aka r send according to naughty cal) for shopping
The point being that his boat was my pontoon as my intention was to simply stop and shop.
I wouldn't be that keen to stay for a night or two beside someone else to be fair.
Why would you not be keen to stop the night?
The only reason that you are required to turn your engine off in Thames locks is so that you can hear instructions from the lock keeper.Can I just make another point about narrowboats and running engines in a lock.
In a narrow canal, it's normal not to tie your boat in a lock. It can't go sideways. So it's normal to keep the engine running and use it to maintain position so you neither hit the lock gates or get stuck on the cill.
Perhaps all that is needed it to politely tell a narrowboater used to the canals, that since you are tyeing your boat up to the bollards, there is no need to keep the engine running. It's probably nothing more sinister than they never thought there was a need to turn it off.
That's what you assume, but it's not the reason that the EA require you to switch off. As I said, It's so that you can hear instructions from the lock keeper.It's to stop the lock being filled with diesel and petrol fumes.
You are familiar with the river, but in the canals it's quite normal to leave the engine running in the locks.You may well be correct, but I've been in my tender in a lock with a boat who left his engines running and I was choking on it. You don't run car engines with the garage door down, the same applies in a lock. I think you have to be in a tender or a kayak to appreciate how nasty it is
I appreciate that, but we're discussing the riverYou are familiar with the river, but in the canals it's quite normal to leave the engine running in the locks.
