Name that non-return valve?
Firefly211
7 Oct 2010
North Wales
does the collective have any idea what these type of non-return valves are called? I’ve a couple in my pump out system that are getting very tired and I wanted to google some new ones.
Thanks.
Don't swing check valves usually have the flap held on a metal hinge? The OP's photo shows an all-rubber hinge, like the ones on marine toilets.
It is still a hinge with the hinge function provided by the flexible rubber hinge. Just have to make sure the hing flap sits in the right place to operate correctly.it is incorrect in the picture as the hinge should be at the top.
They were fitted before and after a Vetus EMP113, but they are not Vetus products as they seem to use duck valves. It seems Beneteau put these into the system instead for some reason.
Just to assist your Googling, on Raritan toilets this is called a "check valve"...
