monkfish24
Diadem's (SeaWolf 26) hatch was long overdue being repaired and we bought her witht he hatch needing replacement, or at least the woodwork being renewed.
I've dismantled it and the lateral pieces are made of a solid piece of wood which has been shaped to make a curved piece. Doing this will take too much time, a large piece of wood and will be very hard to shape in a smooth curve. A friend of mine is very good with woodworking and suggested the following method, cutting a piece of wood into thin strips and then epoxying them, using the original frame piece as a template.
I understand Cold Moulded ply boats were always done in this manner but have never seen it done and this is my first time trying this method.. So, for those who want to try the same technique's, here are a few photo's.
This shows the original piece (top) which is obviously well rotten. The pieces of wood on the end allow for the spring after the new piece is epoxied and it should hopefully be around the right curvature. It had gone soft on one end so I cut this end off and put a double length piece of wood in. The two battens are screwed into the original.
These next pictures show the middle cross member just placed on top to show how close to the original curve it is.
These haven't been epoxied yet as I'm waiting for the temp to go up a bit, the petrol generator isn't quite man enough to run a heater in the garage
